M
MichailS
Guest
Hi
I have an assembly that I did some FEA on, and now I can't remove the material from the part models anymore.
If I go to Edit→Setup→Material I see the window with the available choices to the left and a ►STEEL to the right.
If I try to delete the material, I get "The material is referenced by Simulation Entity. Please remove the dependencies before deleting the material."
So I go into Pro/M and I remove the material assignment from the model, but it doesn't help. There is still a Material-STEEL entry in the model tree and I still get the above failure when I try to remove the material.
Err.. what now?
Err.. what now?
