Remove Tool
  • Thread starter Thread starter Rajiv777
  • Start date Start date
R
Rajiv777
Guest
I want to know what is the use of remove tool exactly and what it does?
Can anyone explainme with a simple example?
Rj.
In simple words, to use a surface to cut away solid material with.
I use it to make smooth transitions in flow paths, where you need organic shapes that would be difficult to model unless using boundary blends.
Ankarl -I assume you mean remove when using solidify?
I would say that "remove tool" , located under "edit - remove" is used for removing unwanted faces, like fo ex if you want to remove a round like in this part:
(resume the supressed feature)
2012-08-30_024658_remove.prt.1.zip
//Tobias
Yes, you're right, I was mixingthe terms...
The removal tool is very useful when simplifying parts for FEA or CFD studies
Edited by: ankarl
