remove interfere volume
  • Thread starter Thread starter bosssss
  • Start date Start date
B
bosssss
Guest
I have two parts in an assembly that interfere....because I have re-designed the second part. Using the global interference command I see that interfere 12mm3..
Is there a command to remove this volume from one of the two parts???
Long time since I used this but you should be able to make a part of the interference volume, then use the cut-out feature.
This is many releases back, so there might be another method today....
Maybe this help you. In 2001, Component > Adv Utils > Cut Out
Wouldn't it be wiser to modify the other part by parameters until the interference is gone ?
Alex
