A
adam.nagy.90
Guest
Hi there!
I have a problem in Creo2, the details are the following:
I'm designing a front suspension for an Formula Student racecar, and I need to generate special graphs like wheel travel - camber angle. The angles are measured and defined as a feature, so the parameter is available. The problem is, that if I (or the servomotor in the analysis) modifies for example the wheel travel or the steering rack, the angles are not updated, only after regeneration.
Unfortunately in Mechanism the Creo does not regenerate the features in the substeps. I tried the same with Sensitivity Analysis, but that couldn't help either.
Thank you in advance,
Adam
Adam
