V
vandewinckel
Guest
Good Afternoon,
I'm using wf4 Date code 130. Is anyone having problems withfamily table instancesnot updating after the generic has been modified (instance has been verified). Example : I have a genericpart with ainstance,the hole positionin a pattern table was changed on the generic part, I made the change to the generic and verified the instance, everything looked ok a this point. I opened theinstance and the updatehas not beenchanged. I regen'd theinstance and nothing changed. The regen in theinstance kept allowing it to regen several times without stating "not changedsince last regen" The message on the regen said completedand still let it regen again.I had to edit definition on the hole pattern table for the update to be completed in the instance.
Thanks for any response
