Reg : PTK Start-up help required
  • Thread starter Thread starter zynk
  • Start date Start date
Z
zynk
Guest
Greetings!!
I'm completely new to Pro Toolkit and for this forum as well. By referring help files, I built a DLL, created a DAT file and Registered as an Auxiliary Application. I could able to see that the DLL is running....
According to DLL, it should create a Menu in which PUSH BUTTON available.
Where could I see the Menus of corresponding DLL?
Anybody's help will be greatly Appreciated.
Zynk
Greetings!!
Zynk
There is no seperate DLL especially for menus. The only output DLL contains all code for creating menus and push button and all other operations. Inside your source code try looking for API's such as ProMenubarmenuMenuAdd() used to create menu and also see @ what position they are added.
