7
78finn
Guest
I have been using Pro Engineer for about 6 years now...and am fairly comfortable with most aspects of it...but it never hurts to see what other people are up to and why.
The main thing I'm interested in is how people go about referencing complicated assembly's i.e. 100+ components, heavy surfacing and multiple linked mechanisms. I'm largely self taught when it comes to Pro E...so I'm just wondering what everyone else out there is doing?
The method I current go with is Top Down assembly.
I usually create a skeleton assembly or have sketches, datums etc. at the top of the assembly tree for all components to reference from.
Then for each part I will either reference from these sketch's/datums directly from the assembly or activate the part in the assembly and copy/paste the references into the parts themselves.
Another method I employ quite heavily is to make a surface copy of a parent/driving component within the part i.e. including draft and and major radii. And then in my assembly I will activate the desired child/dependent part and copy/paste the surface copy of the parent into it. I can then reference off of the surface copy so that any subsequent changes to the parent will update the child when regenerating the assembly.
These methods have served me very well with regards to the stability of my larger assembly's, but its quite time consuming to setup.
Does anyone else have any techniques that they would be willing to share with regards to referencing?
Edited by: 78finn
Edited by: 78finn
