LucasAU
- Oct 15, 2019
- 3
I have a two storey building consisting a concrete slab at first floor and a steel roof.
There are 2 core walls in the middle and 12 band beam running in Y direction with 8m spacing supporting 260mm concrete slab. Each band beam is 5 x 8m span = 40m long. So the dimension of the building is quite large (120m x 40m).
Now I have worked out the overturning moment from wind in X direction is 3000kNm while 8000kNm in Y direction. The axial force in each core is quite small (2000kN) because they are locating at the edge. Considering this, if I design the core wall footing to carry the whole overturning moment, the size of the pad foundation will be quite large. (founding material is basalt rock with 800kPa allowable bearing). So I am wondering if I can reduce the core pad size and consider the beam-column frame to take the overturning too?
Simply put, if the building has no core wall then the lateral load will become axial force in the columns of the frames (still pin the column-pad footing). In another word, can I reduce the footing size of the core and let it rotate under lateral load so then lateral load will go to the frame and result in axial force in each column? What about the X direction (considering there is not beam running in X direction)?
