B
bigconsultant
Guest
I have having trouble modifying the attached part to the
new required specification
The file is here
http://thebigconsultant.com/downloads/Multi Part Moul
d%20Iss2.1E.zip
The problems are:-
- I need to resize it
- Rebuild errors, and very slow rebuilds
- Complexity of model
I am now strongly thinking that I need to redraw the
product from scratch. This may be quicker, and also make
the model more elegant and easier to use, and adjust.
I think that the main problems that I have come from the
very way the model was built, using the surface lofts
right in the early stages. There has always been a
problem with the surfacing at the front and rear curves
where they join at the extreme front and rear.
This has had knock on effects, and it taking up too much
time. Also, the rebuilds are now horrendous. And I am
running quad core at 3.8Ghz with 8GB ram!
I think that I need to look at a radical new redraw.
Maybe using features differently from the off, that will
provide more consistent and reliable results. However, I
do wish to keep the exact same shape and profile.
I think that this will be important for the production
issue, also. As this is a prototype. I will need to
easily make changes to draft and other details. So I
think a new model, looking the same, but drawn
differently is mandatory.
I am especially thinking that the "surface lofts" right
at the beginning are causing problems. With surface lots
the geometry seems very 'ragged' at the extreme front and
rear. This requied patching, and in fact I think "surface
lofts" might often experience this problem.
I am looking for a method to completely redraw quickly,
and neatly, and maybe suggestion of a new way to draw
this exact same shape, but without using surface lofts
maybe? It has led to many rebuild problems when I edit,
and I think I need an elegant new basis, to achieve the
same effect. But in less steps, and more reliably!
Please could anyone advise?
Kind regards,
John Biddleston
The file is here
d%20Iss2.1E.zip
The problems are:-
Kind regards,
John Biddleston
