[RAM Concept] How do I fix "Punching check not at column" error?
yoohooos
I have a couple of error with Punching check not at column Type. How can I fix this and what should I be looking at?
Do you expect us to know what program(s) you're using, or what you're trying to do with it?
Dan - Owner
@MacGyverS2000 I'm pretty sure the program name at in the header. My question was just what that error is about, not sure why it should be more specific.
Did you move columns after you created punching checks? You need to view the layer that shows your punch checks, identify which one(s) are no longer located on columns, and fix them.
You may have moved the column but not the punching check zone. Try deleting all of the punching checks and replacing them. By trial and error! And then a lot of different information is written on the Internet and gossip about the solution of this problem!
