SteelPE
- Mar 9, 2006
- 2,759
I am trying to design a slab on grade for a project that I am working on (see other post about forklifts). Attached you will find a design chart and example from an old text I have called “designing Floor Slabs on Grade”. For reverence, this same chart is used in ACI 360R.
I am a bit confused as to what loads to apply to the posts/slab. The design example assumes a 5-level shelf at 100 psf with a base plate of 20 square inches (16,000 lbs). However, this appears to be based on an assumption that the column in the middle of two back to back racking stems will take all of the load onto one 20 square inch plate (to me is should be supported on two plates). I can’t say that I have seen a racking system built like this before as every racking system I have seen has two sets of columns in the middle separated by 6”-8”.
So what load would you used when designing a racking system with two back to back set of shelves (two separate columns on two separate base plates)? Would you use 8 kips on 20 square inches or would you use the full 16 kips on 20 square inches?
