Combining real numbers and strings gets complicated. You
do have to convert the real numbers to text first using
ITSO. Below is what I use for a plate. HOR, VERT and
LENGTH are dimension names of the plate. W1, H1 and L1
are temporary values for the code. I use IF statements to
get the correct number of characters based on whether the
value has a tens place or a hundreds place. INCH is a
string parameter I added and assigned the value "
IF HOR < 1
W1= "."+EXTRACT(ITOS(HOR*100),1,2)
ELSE
IF HOR< 10
W1=EXTRACT(ITOS(HOR*100),1,1)+"."+EXTRACT(ITOS(HOR*100),2
,2)
ELSE
W1=EXTRACT(ITOS(HOR*100),1,2)+"."+EXTRACT(ITOS(HOR*100),3
,2)
ENDIF
ENDIF
IF VERT < 1
H1= "."+EXTRACT(ITOS(VERT*100),1,2)
ELSE
IF VERT < 10
H1=EXTRACT(ITOS(VERT*100),1,1)+"."+EXTRACT(ITOS(VERT*100)
,2,2)
ELSE
H1=EXTRACT(ITOS(VERT*100),1,2)+"."+EXTRACT(ITOS(VERT*100)
,3,2)
ENDIF
ENDIF
IF LENGTH < 1
L1= "."+EXTRACT(ITOS(LENGTH*100),1,2)
ELSE
IF LENGTH < 10
L1=EXTRACT(ITOS(LENGTH*100),1,1)+"."+EXTRACT(ITOS(LENGTH*
100),2,2)
ELSE
IF LENGTH >= 100
L1=EXTRACT(ITOS(LENGTH*100),1,3)+"."+EXTRACT(ITOS(LENGTH*
100),4,2)
ELSE
L1=EXTRACT(ITOS(LENGTH*100),1,2)+"."+EXTRACT(ITOS(LENGTH*
100),3,2)
ENDIF
ENDIF
ENDIF
DESCRIPTION= "PLATE, " +W1+INCH+" X "+H1+INCH+" X
"+L1+INCH+"LG"
