Quick method to remove a fillet
  • Thread starter Thread starter ericscottf
  • Start date Start date
E
ericscottf
Guest
Hi folks
When drawing a sketch, what's the fastest way to go from having a fillet to a sharp corner?
Right now, I delete the fillet, drag endpoint1 past endpoint2, Extend endpoint2 to endpoint1 with the extend tool and trim endpoint1.
There's got to be a better way.
For instance, in acad, you can delete the fillet and then make a new fillet with a rad of zero (not possible in sw2009 as far as i can tell)
anyone have a nifty trick?
Try Control-selecting the endpoints and select 'Merge' from the relations menu that appears.
yup! thanks!
