Hi all,
I'm very interested in how anomalies in embedded rebars within concrete walls are detected and assessed, and would appreciate insights from professionals in this field.
I have a few key questions:
Thank you!
- What are the most common rebar anomalies inside concrete walls? Is rebar corrosion the main concern?
What detection methods are typically used, electrochemical?
- Are non-corrosion anomalies also important to monitor?
- Can rebar fracture occur in practice (e.g., due to earthquakes or severe corrosion), and is it a real concern?
- What about bending of rebar or spacing shifts between rebars, do small deviations impact structural safety or require attention?
Thank you!
