QUESTION OF DOMESTIC TANK 1
GUO ZHIQIANG
9
I have a problem.
I am now designing a plan for an airport project.
The main problem is that the sustainability of municipal water supply is very poor, so I need a pool to store domestic water to ensure continuous water supply.
Now I plan to store water for 3 days, but how to calculate the daily water consumption of airport passengers and airport employees is a problem.
UPC%E6%B1%A1%E6%B0%B4%E6%97%A5%E7%94%A8%E6%B0%B4%E9%87%8F%E6%88%AA%E5%9B%BE1_q1my1q.png
I consider using UPC Table H 201.1(4)
Is this feasible?
The UPC table is acceptable. The airport probably will need a pond anyway for fire flows.
Unless this is an airlift with one flight a day you are going to need a vast "pond" in which to store water for 3 days operation.
Also see NFPA codes & sstandards.
And likely tow separate systems for fire fighting and other uses.
