Question for Structure with Viscoelastic Dampers in perform 3D
sky1379
ID
Hello i'm angga, currently doing master's thesis, I have a problem, currently i already finished run structure with VED in perform 3D but when i see energy dissipation in VED i really small compared to total energy from the ground motion, beam was dissipating energy the most compared to column and VED, since VED is energy dissipation devices it should be the one that dissipated energy the most right? where did i do wrong in this model?
