Query to see if part is open Journal, NX 11
3dr
Automotive
I'm trying to use the code below to test if a part is already open in the session.
If False, Show message box and don't execute the code.
If True, Execute the rest of the journal.
But I'm getting a "MessageBox is not declared" error
What am I missing here??
Imports System
Imports NXOpen
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As NXOpen.Session = NXOpen.Session.GetSession()
Dim workPart As NXOpen.Part = theSession.Parts.Work
Dim displayPart As NXOpen.Part = theSession.Parts.Display
Menu: Assemblies->Components->Add Component...
Dim pfile As String = "Proj Data.prt"
For each openPart as part in theSession.Parts
if openPart.FullPath = pfile then
MessageBox.Show ("part is already open")
else
MessageBox.Show ("code to open part")
end if
next
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX1851, Win 10 Pro
Add the following to the imports section:
Code:
Imports System.Windows.Forms
OR fully qualify the call to the message box
Code:
System.Windows.Forms.MessageBox.Show ("part is already open")
www.nxjournaling.com
Qualifying the Message Box did the trick.
Thanks Cowski!
Dave
NX1851, Win 10 Pro
