blihpandgeorge
- Nov 5, 2012
- 102
Hi
I wanted to get some opinions on what is the easiest / best software for purlin / girt design, i am Aus based so prefer something that uses AZ/NZS 4600. If it doesnt have Aus section properties built in i am happy to import them manually if needed.
In particular i would like something that automatically address the various patch / local pressure loadings required in AS1170.2. Manually determing the correct 4:1 aspect patch for different Kl values and placing them in different spans / locations is pretty laborious to do manually and properly.
I have seen the Stramit EX-Facta which is pretty good but requires application of local pressures manually. I have also seen Supa-Purlin and it also requires manual input of loads.
Any other suggestions?
