Purge Creo part & assy files
  • Thread starter Thread starter willem75
  • Start date Start date
W
willem75
Guest
I have just moved to Creo 2.0 and am familiar with the "Open System Window" and purge function to remove older instances of part and assy files etc. However I can't seem to do this anymore once moving to Creo 2.0 (although I suspect this may be related to my new PC rather than the software.
Anyway, I was hoping someone could help me with this issue, when I try purge I get the following error message in the command prompt window, "'purge' is not recognised as an internal or external command, operable program or batch file."
Any suggestions are appreciated.
Will
You probably do not have your windoze PATH environment variable set to include the path to the <load_point>\Parametric\bin directory.
