  • Congratulations 3DDave on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Pulsed IR
skuntz
Chemical
Mar 16, 2008
69
Forgive me if this is a very basic question, but at my business we are using IR emitters for gas detection for the first time.
What are the reason(s) that IR sources are pulsed?
That would depend on the application and the design.
In most simple detection systems, you need to compare "signal" versus "no signal," which can often be accomplished by pulsing the source.
Pulsing, or modulation, can often be used for symchronous detection schemes, that result in substantially lower noise, which affords either better sensitivity, or lower cost detectors.
TTFN
FAQ731-376
How does modulation achieve lower noise?
