Hello I need to hardness test a PTFE rotary seal to compare to the version we have received from a supplier. The issue is the PTFE seal is 1mm thick and I am struggling to find a hardness scale that can accurately depict the hardness of the OE compared to our production sample.
Does anyone have any recommendations as to which hardness scale i need to use to grab some accurate data given the gasket is so thin.
Thank You!
Thank You!
