PSR_1
- Aug 9, 2016
- 56
The Slab am supposed to design has walls at the four corners and the restraint the walls impose is killing my effective stress in tendons and I suspect restraint cracks will be visible after construction. Since it is structural wall slip joint isn't a possibility and pour strip doesn't seem to work since the walls are at just the four corners( Correct me if it is possible to use pour strip with walls located at certain locations, I only have experience with basement walls). Is there any other way to counter the effect of restraint?
See the attached picture.
