  • Congratulations IRstuff on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Protein Supplementation via BCAAs
Mechanical Farmer
40
If targeting 200g of protein daily for maintaining muscle mass.
Considering that BCAAs are the building blocks of protein, can BCAAs be used to replace protein should a source of protein not be available?
Assumptions:
Not all proteins sources contain the same BCAA profiles.
Essential Amino Acids need to be included in the BCAA blend.
There are certain BCAAs that need to be consumed to synthesize muscle proteins.
All other Macro and Micro Nutrient requirements are met.
Most things from people I trust say that BCAAs are not needed. Typical protein supplements cover the bases.
200 g of protein seems a bit high for just maintenance
If I'm being completely honest, I'm trying to maintain a caloric deficit, so I'm trying to get protein in the morning via BCAA rather than a calorie dense meal. I also get some caffeine through this as well.
Many of the protein supplements are high calorie targeting weight gain.
First goal is to determine the ratios and quantities required to match protein, then determine if anything else is needed for bioavailability.
Roughly 1g/lb. This is on the high side of the recommended range, but better safe than sorry.
