T
toonyank
Guest
I've got a fiberglass water tank that we are going to be fixing side panels too. The resulting thin panels should look relatively flat so we are having mounting pads glassed in along the sides and I want them to be coplanar within a to be determined tolerance. Is the proper geometric tolerance to be specified "surface profile"? I'm fairly certain that this will convey the message clear enough.
Thanks guys.
Thanks guys.
