Propeller drawing in ProE
  • Thread starter Thread starter joseph_atkinson
  • Start date Start date
J
joseph_atkinson
Guest
Hi Does anyone know where I can get hold of a propeller part file for ProE Student? There is one already on this site....but it isnt suitable for the Student version
Many thanks
Joseph
Hi:
if you wf2 send me a e-mail address i'll send a copy of one.
Joseph,
Not meaning to a wiseguy or anything. You are going to run into trans. problems into the Student Version
Give it a try and model it up yourself, best way to learn Pro is to fight with it some
that what the student vers. is all about. Comb the web a little , get some specs.
Then give it a whirl
, then IF you need some help with some specifics, I'm sure you will get the responses you need and YOU will benefit more in the long run.
BTW which version ?
can anyone help me in modeling a propeller blade in pro-e wf-5???
plz mail me at karrikumar@gmail.com
Karri Kumar
karri Kumar
There is a video on youtube viz. Variable Section Sweep demystified. have a look at it and study the command in detail.
Secondly, for a new question, please start a new post. That way your chances of getting a proper reply are higher.
Student editions can read neutral file formats like igs or step created from commercial versions. Only the feature history will be lost. You may however use "Feature Recognition" tool which is freely downloadable from ptc.com. however, please check whether it works with the student version.
