Larryhd2
- Dec 10, 2004
- 48
I'm engineering the anchorage and footing for a 1000gal propane tank... it's for a school and it's used to serve a generator that serves pumps for fire suppression in case of power outage, so it's Risk Category III.
The steel tank is 42"dia, 16' long and lays horizontal supported on 4 "feet" welded on the tank. The feet are then bearing on and anchored to the slab/footing.
I've looked through all of the design parameters in ASCE 7, but I'm not engineering the tank, just the anchoring and foundation. Is there a simple factor like some percentage of Sds I can apply to design the anchoring and footings?
