Program states in drawing mode
  • Thread starter Thread starter willwad
  • Start date Start date
W
willwad
Guest
Does anyone know if you can execute a state in a drawing based off of the value of a parameter?
For instance, I have a boolean parameter called Test. When it is set to yes, I want the drawing to execute State Test. Is this possible to do?
In the drawing, edit the program (Advanced > Program > Edit Program) and add:
if Test=yes
set state Test
endif
Then change the value of Test and regen the drawing.
Ed
