uh, not sure what the question is, but here is how to create a JPG.
When you drawing is active, click FILE > PRINT and add a use Add Printer Type... and select JPG from the list. Then be sure to use the Configure option to select your sheet size. If you don't do this, the text could be fuzzy. Then select To File option box. Pro-E will try to give it a plt file extension, just change this to jpg and you are good to go. You will probably want to select a new file location as well.
