ProE Cabling
  • Thread starter Thread starter Jacon
  • Start date Start date
J
Jacon
Guest
Hi All
We have the ProE Cabling extension at work and no one can use it as yet. I nd 'n few guys are going to go for training next year.
Is there maybe some training material out there for WF4.0 that I can get to start to practice.
Any information will be helpful
Thank you
Hii,
I have it for WF-2..I dont know, howmuch difference is there between WF-2 & WF-4...
May be helpful to you:
2011-08-17_051256_cabling_WF-2.zip
Thank you very much.
I will go through it and see. I don't think it will be that different.
You could get a PTC-U subscription and learn a lot online.
Thanks I will give that a try and see if I can.
Hello
I got stared in RSD8.0 and exported an .XML file, but when I try to import in Pro/Cabling it gives me an error.
The error says "failed to parse xml file"
Can anyone please tell me what this means and how to fix it.
Thank you
THANK YOU SACHIN .FOR YOUE SUPPORT
where i can get proe cabling tutorial
please help me
regard
vijay
I have learned Pro-Cabling by stitching together the little material that is available on internet.
The tool by itself is quite old, and with all the contextual menus scattered in the most unlikely way reminds me a lot of Catia 4 (damn I am old), for which the only way to get some knowledge was to leech it from someone older than you.
Anyways, I found valuable the tutorials from www.frotime.com.
They are not omnicomprehensive still they provide a good starting point.
Subscribtion fee is needed but is little more than a good CAD user manual.
Hope it helps.
