Nov 26, 2002 #1 K kkpele Guest I'm having problems in the very first screen of the setup. On the bottom right hand corner it shows the Hostname and the PTC Host ID. For host id i get error in plp_host Help....
Nov 26, 2002 Thread starter #2 N nemecek Guest Hi, I had same problem. Try check your TCP/IP seting or type of your CPU ( if you have a AMD K6 type procesor, than there is the problem) regards LN
Nov 26, 2002 Thread starter #3 N nemecek Guest Hi, I had same problem. Try check your TCP/IP seting or type of your CPU ( if you have a AMD K6 type procesor, than there is the problem) regards LN
