Producibility warning
  • Thread starter Thread starter Heroic76
  • Start date Start date
H
Heroic76
Guest
Hi there, I'm a new forum member,
I have a difficulty to do the producibility, we tried every method possible but still failed, (indication and geometrical center)
For your information, this happen when we tried to do the but splice for the plies
Sorry for the delay. I'm in the middle of learning CATIA Composites myself and I just learned about the flat patterns.
Hopefully by now, you figured out your problem yourself.
To me, the message is pretty clear, but I don't see where the flat pattern intersects in the image you attached. Zoom-in and rotate the model to find where the problem is, and hopefully that will help you figure out what you need to do.
