Process Manager
  • Thread starter Thread starter iharter
  • Start date Start date
I
iharter
Guest
I need to configure the manager processes to contain the information:
Reviews of the operation(Operation Setup > Output > Comments)
Comments tool( Tools Setup > Settings > Comments)
Radius compensation(Edit parameters of sequence > cutcom > ?)
CUT_FEED
SPINDLE_SPEED
Z AxiS minimum
EXAMPLE:
FIRST FIXING
CONTOUR GRINDING
10 CUTTER DIAMETER
CUTCOM ON OR OFF
CUT_FEED 10.000
SPINDLE_SPEED
SECOND FIXING
CONTOUR FINISHING
10 CUTTER DIAMETER
CUTCOM ON OR OFF
CUT_FEED 10.000
SPINDLE_SPEED
thank you
