Problems on exporting an AUTOCAD 2006 draw
  • Thread starter Thread starter spyros
  • Start date Start date
S
spyros
Guest
I want to copy a vector drawing from AUTOCAD 2006 to flash but I am having some difficulties.
I have made a ground plan of a map in AUTOCAD. When I select a small part from the map with a small number of points and I copy it to flash the drawing is copied very well with no mistakes. The problem is when I am trying to copy the whole drawing. The copy function isn’t work correctly the lines on flash is been destroyed and the drawing isn’t correct.
I also tried to copy it first in Illustrator and then from illustrator to flash but I have the same problem.
I also tried to copy it to illustrator but the result is very bud the lines are destroyed especially the lines with thickness.
