Problems in creating rib
  • Thread starter Thread starter sekar_r24
  • Start date Start date
S
sekar_r24
Guest
There is problem in creating a rib between a cylinder and the flat surface, when the rib profile is started from the cylinder. It leads to resolved section. How to rectify this?
hi
send an example picture of your model
szymkowiak@op.pl
hope this helps
if u want to make a rib anywhere just make a datum to go through the
flange axis and @ a angle to one of the datum planes. then use it as
your sketching plane.
if you want to pattern it like in the second pic. group that rib and
datum and pattern them together. also if using wf2. just use axis
pattern.
