A
Andymellor
Guest
Hi, I have an assembly drawing created from a Pro/Process model. The drawing contains a sheetfor each assembly step. On each step I have inserted one of our standard BOM Tables which lists description, part no. and qty. I am having to filter out the parts from the previous step that I don't need for the current step which is fine. My problem however is to do with the qtys. On some steps I have the same fixings (screws, washers etc) that are used on previous steps and what is happening is that the table is adding the qtys from the previous step and I only want to show the qtys on that particular step. I cannot filter them out or I will lose the actual fastener itself. Is there any way of associating the table with each step or another way of solving this ?
