M
Mans
Guest
I drew two concentric ellipses on two different plans and made a surface with multi-sections along with a guide but as you see three irregular lines are created on the face. I did repeat the operation a few times but the result was the same, though the distances between the lines are changed. What is the reason and how I can correct it?
Thank you
Thank you
