E
EagleEye
Guest
Guys ,
I found very strange problem while working with Pro E drawing.
Let me explain:
Suppose in Pro E drawing , the part has length measuring 50mm.
and if I save as that file in .dwg format so that i will have better access to that drawing in Autocad.
But in Autocad, when i measure the same length , I found it 0.1235.
How this is happening ?? what is the solution for that? (Dont tell me to every time edit the dimension and change it to 50mm)
Any kind of help would be appreciated.
Let me explain:
