M
mailforu158
Guest
Hello guyz,
I am trying to import a .dwg file into pro/e sketch environment, using the following procedure
Sketch -> Data from file -> File system
But it gave an error which says "The specified DXF file does not exist."
I am using PRO/E wildfire 4.0 (student edition) and I am using the .dwg file generated from the Autocad 2009 (trial edition)
What might be the problem ??
