S
skwasim_smile
Guest
hii everyone,
Coming back to the forum after a very long time,I have received a file in IGES format which has only curves for the model,I have to build surface using these curves below attach picture will give you perfect idea,My problem is that boundary requires 4 curves to build surface but there are some areas in this model which has six curves,I can't split these curves adding extra curves as I don
