Pro/E Wildfire 4.0 Dimension Relations
  • Thread starter Thread starter lukas108
  • Start date Start date
L
lukas108
Guest
Hi.
I've recently been trying to use relations to reduce the amount of dimensions i need to edit when resizing my part.
This usually consists of Tools > Relations. Then adding something on the line of
sd1=10
sd0=sd1*10
This works for me inside of sketches. But Outside of the sketch, on the main level, it will not work. For example
d0=10
d1=d1*10
Can anybody help me with this problem?
Thanks in advance, Lukas
d1=d1*10
That won't work, you have the same dimension on both sides of the equation
Hi, Thanks for your reply
That was my mistake, for the example i mean d1=d0*10.
The problem i am having is it wont let me create relations on the top level, only within the sketch. I would like to create top level relations so i can include extrude length and cross feature relations.
Does this highlight my problem more?
Hi, problem solved. The relations do work, i started my part again, and it worked fine. I think the problem built up, i know define my relations at every step, rather than all at the end.
