P
pyro
Guest
Hi Fellow users
Ihave tens of Pro/e parts & assm without the use of start parts. I fixed them as follows:Save the start part as a neutral file. Open my work part and insert data shared and pick the neutral file. This updates the parameters and relations, then i follow up with mapkeys to create notes, layers, etc.
Problem is that it doesnt work with assemblies. In my work part, the insert data shared doesnt find neutral files. Only option is ecad idf (*.ecm) and poltxt (*sol).
So how do standardize my work assemblies with the start assy? How do i automate the process more efficiently without opening each file manually? Alsoi read someone post, see below. I am wondering what do he mean by that?
"However, you will need to set config option new_parameter_ui = no as mapkeyscan't access the graphical parameter box."
thanks
thanks
