Printing using the MS Printer Manager..
  • Thread starter Thread starter james.lynch
  • Start date Start date
J
james.lynch
Guest
Hi, I'm wondering if any of ye has had any luck printing Drawings using a standard A3 (or A4 for that matter) colour laser printer? What setting can you use in the print Dialog box?
All I get out is some text gibberish or a .pltfile (which I presume is for a plotter which I don't have)
your help is appriciated,
James
james you are everywhere...........................
That mind you have a lot of work to do?
try the configuration
In the print dialog box you have some optionView attachment 687View attachment 688
Yes I am!
I have given myself this academic year (half way through!!) to learn as much about Pro E as humanly possible! so yeah, Lots to do!!
Anyway, that helps.. I was doing something stupid with the paper sizes.. woops!
Thanks for the help!
look forward to pestering you again later!!
