B
BUSTERCHOPS
Guest
Hello, I have a 2D layout in 3D that I need to print. The layout has areas that have fills or are shaded, balloons. When I print the shading disapears? currently I am using the screen capture set to Vector Mode then when I select print I set it to Rasterization, this will allow the shaded boxes and the font in the boxes to print but then all of the line weights of the view are changed to one size. All font has been added in FT&A. I have also experimented sending the layout to a .dwg from an annotation plane then using view from 3D. I get the font in the balloons but no shading and the line weight changes to one thk. This way I am not sure at this point if I am getting the correct scale. Any ideas? Thank you MJ
