Nov 11, 2002 #1 G gtr207 Guest How to set up the thickness of different lines(Object,Dimensional, hidden lines,tangential lines) while taking Drawing print out in the HP DesignJet 700 Printers directley from the WIN NT4.0?
Nov 11, 2002 Thread starter #2 P proed Guest Hi You can use the pen settings in your config.pro, for example: pen1_line_weight 3 pen2_line_weight 1 ...etc... BTW, here are some of the common pen assignments: 1 - geometry, curves 2 - dims, leaders, axes, etc 3 - hidden lines 5 - sheetmetal color
Nov 11, 2002 Thread starter #3 D dougr Guest You can also create a table.pnt file, search your help documentation for this expression...
