Principle Calculation of Stresses at Sections - Crane Frame for Vehicle mounted cranes.
JarlSim
Automotive
May 25, 2022
1
Hi.
I am trying to define a set of calcuations to determine if a specific cross section of a frame structure is strong enought to withstand forces applied to the cross section.
I have reviewed standards and regulations for clues towards defining the calculations needed for the above stated problem, but have thus far been unsuccessful.
My question in brief;
Based on force applied to a frame structure due to load lifted by a loader crane mounted rigidly, how can i determine the stresses in diffeent cross sections of the frame structure?
My need is to optimize the cross sections for several sections along the length of frame to reduce weight but still acheive a safetyfactor of at least 1.2 from yield strength.
I have attached a simplified sketch to illustrate my question.
I would appreciate any input to help me solve this problem.
 https://files.engineering.com/getfile.aspx?folder=0d058daf-07ea-4357-baf4-05877b97fcdc&file=Simplified_Sketch_-_Stresses_at_Sections_of_crane_frame.pdf
First draw a free body diagram to get equilibrium
Then draw your shear force diagram along the beam
then draw the bending moment diagram.
Then you know that M/I=s/y
where s is the stress at a height y above or below the neutral axis at that point.
In your case you've got two forces at the base of the crane so you could apply each individually and use superposition.
Cheers
Greg Locock
how is the crane boom connected to the lower beam ?
what loads is the crane boom applying to the lower beam ?
as greg says, draw a FBD of the crane boom, then a FBD of the lower beam.
this'll show you that the RH reaction is larger than your applied load
If I understand your stress sketch (stress1 to stress4) ... I don't think the stress (whatever stress you're talking about) is heading to zero.
