AleksaBgd94
Hello everyone,
I am working on the simulation of the behaviour of masonry infill under out-of-plane loading. You can see on the photo attached how the load is assigned (direction of the out-of-plane load). I assigned the uniform load (total force) to the wall. What is the best way to have the pressure (force) vs. displacement of one node of the wall plotted?
I was able to plot the node displacement in desired direction by setting ODB Field output - Unique nodal - displacements and then setting the displacement and picking the node. I think the same can be done if the displacement of the node is defined in History output, but how can I get the pressure (force) plotted?
Thanks in advance.
Thanks in advance.
