PRESSPULL CMD not working
  • Thread starter Thread starter Two_Die_Four
  • Start date Start date
T
Two_Die_Four
Guest
The Presspull CMD has stopped working. ACAD will ask "Click inside bounded areas to press or pull." I do but nothing happens. Has anyone had this problem and do know a fix. :confused:
Two_Die_Four
presspull solutions
Two_Die_Four
Hello, You can try some of those tips... How I see here, these command works on regions, that means, you have to have regions to pick up.. So to do a Region you can use a command Boundary "BO", another little thing, try not to use arcs to draw, try to do Splines, those are easier to pick up on select area and explode the blocks, because those take to much time to be checked. Than after create a Region try to use your command, Presspull or (Ctrl + Alt) on that region you want and see if this works! There is another thing, those command works picking any region that is on you cross selection box, so make sure the option in "Tools > Options> Selection" (When a command is active) the check box is on, than where you move you crossbox it will pick a region...
I hope that help!
.....make sure the option in "Tools > Options> Selection" (When a command is active) the check box is on, than where you move you crossbox it will pick a region...
That did the trick . Thank you for the help. :)
two_die_four
