pre-processing boundary
  • Thread starter Thread starter zstatus
  • Start date Start date
Z
zstatus
Guest
Hi
Im running an analysis on my gear but reading the info from the dialog box the process halts at 98% pre-processing boundary then starts to fall to 90% after 20mins. Rather annoying
Iv run a geometry check and there are some errors. Is there a quick and easy way to fix them?
Any help would be appreciated,
Andy
Locate the exact area that contains actual problem. Make a smooth surface and perform geometry check. Then mesh it and make dense mesh in that area. Then perform ur analysis. It may solve ur problem.
Jayanta Sarkar
Application Executive
RHS engineering Services
