Bor_An_Struc
Hi All.
I am a early structural EIT trying to design post Installed anchors on to 75 mm thick RC concrete wall panels.
The minimum thickness of the concrete member needs to be effective depth of anchor +30 mm cover which does not work. ( Hilti tables). The triangular structure made out of angles is supporting small W beams with the shown loads.
Is there a way to design the anchors for (shear + tension)?
Thanks.
Thanks.
