pappyirl
- Oct 9, 2003
- 54
Hi People,
Wondering what your thoughts are on post fixing punching shear reinforcement with an anchorage only on one surface.
Typically we would post install a bolt with washers top and bottom mimicking the reinforced bar equivalent to enhance punching shear on an existing slab.
Recently a number of clients have requested increasing punching shear capacity without access to one of the surfaces, top or bottom. The inclined bolts do cross the shear failure plane and have an anchorage of some length past the failure plane. They do not however provide the equivalent tie that a bar/bolt anchored top and bottom would provide. So depending on which surface is not available, the punching shear tie anchorage occurs at some point outside the analogous truss strut and tie. See attached for a basic description of the design philosophy.
My understanding was that the truss analogy for shear relied on a strut and tie with the punching shear providing a tie between both. I'm struggling to comprehend how this system actually works.
Thanks.
Thanks.
